Archived from groups: alt.internet.wireless (More info?)
I have a 2wire 1000c portal (combo modem - router) for my earthlink dsl. A
remote desktop is on a USB phoneline adapter. The primary computer connects
by ethernet into the portal. My question is: can I add a wireless router
to handle a couple of laptops and still maintain the remote desktop via
phoneline adapter into the 1000c... . (the primary desktop, I guess, would
go into the wireless router & the router into the 1000c ethernet??) or will
that present some sort of conflict.. thanks
> A remote desktop is on a USB phoneline adapter. The primary computer
> connects
> router to handle a couple of laptops and still maintain the remote desktop
> via
> would go into the wireless router & the router into the 1000c ethernet??)
> or will that present some sort of conflict.. thanks
If I understand you, you use a USB adapter to connect to the "portal". You
can't connect that USB into a wifi router. You'll have to go:
PORTAL -> DESKTOP PC --internet sharing--> Wifi router --wireless--> laptops
So you'll need an ethernet port in your PC that you plug the router into.
It then shares your connection wirelessly to the rest.
