Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Picaview Problem With WinXP Pro SP2
Forum Windows XP : Windows XP General Discussion - Picaview Problem With WinXP Pro SP2
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I recently installed SP2 over WinXP Pro SP1 and suddenly my Picaview
couldn't preview animated GIF files anymore when I right click them.
What is the matter? Could somebody help me please? Thanks in advance.
Sponsored Links
From ACD Systems - PicaView FAQ
<quote>
Question:
Does PicaView 2.0 work with Windows XP running Service Pack 2?
Answer:
No. Once Service Pack 2 is installed on the system PicaView will no longer
function. To get PicaView running again you will need to remove Service Pack
</quote>
See:
http://www.acdsystems.com/english/ [...] &go=Search
Copyright © 2005 ACD Systems
Ramesh, Windows XP MVP
http://windowsxp.mvps.org
"juck jones" <juckjones@gmail.com> wrote in message
news:1122133746.976612.308110@o13g2000cwo.googlegroups.com...
Reply to Anonymous
Thanks, Ramesh for the info. Now, at least I know the cause of my
problem. Of course, I won't remove/uninstall SP2! But is there any
chance that there could be a fix to this problem via registry editing?
Again, my thanks.
Juck
Reply to Anonymous
No idea, Juck. I don't have this s/w.
news:1122211484.186666.303220@g44g2000cwa.googlegroups.com...
> Again, my thanks.
> Juck
Reply to Anonymous
Ok. That's good enough for me. I'll leave it at that. A pleasant day to
you, Ramesh.
Reply to Anonymous
You're welcome Juck.
news:1122213044.003414.120710@o13g2000cwo.googlegroups.com...
> you, Ramesh.
Reply to Anonymous
- 0 +
Picaview's functionality seems to be restricted by Xp Sp2's Data Execution Prevention (DEP) program. Switching it off in the boot.ini file allows Picaview to operate on my machine as normal.
I cannot say this will work for everyone.
To deactivate DEP which you should not do according to some as it may make your computer vunerable to system files being changed, change the the boot.ini file to read:
[boot loader]
timeout=3
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=AlwaysOff /fastdetect
Make sure to make a copy of boot.ini first.
Also please note that Picaview has also been reported as causing trouble for the "Open With..." item on the right click context menu in explorer. So I suggest a back up of the registry as well.
Picaview like TrayMenu from Wei Ke seem to be frowned upon because they give too much control to the end user. At least that is the way it seems to me. Proceed with caution please, but I have found the above works.
Reply to Des246
I was able to get picaview to work with XP SP2 by going to system properties then clicking the advanced tab and going to performance settings. I then clicked on Data Execution Prevention and selected 'Turn on DEP for all programs and services except those I select.' I checked the box on Windows Explorer and then clicked 'add'. Browse to the \program files\acd systems\plugins folder and type *.* in the filename box. Then you select the plugin that is causing the error. In my case it was the IDE_ACDStd.apl. Click apply then ok. You will have to restart the system and everything will work...at least it did for me.
Good luck.
Message edited by bigone5500 on 08-03-2008 at 06:46:31 PM
Reply to bigone5500
@bigone5500...
Your post solved a big problem for me...but I had to make one other adjustment.
Just doing the DEP dance for the Plugins didn't work so I tried - again - to reinstall Picaview - more than once - but I kept on getting the message that (paraphrasing here) "The application could not start because "xerces-c_2_6.dl" could not be found."
So, I went back into the Data Execution "stop you from using your purchased software because MS doesn't want you to use it" section and did exactly the same thing with xerces-c_2_6.dll...rebooted and "Viola!" As soon as XP opened I could use Picaview!
I have copied your post into a notebook file and saved it on an external disk so that it will be there if I ever run into a similar problem again.
Thanks loads!
<Edit to add>: Oddly enough, I tried...just for the heck of it...to install Picaview again, and still received the message about "xerces-c_2_6.dll" but it appears to be just for the Picaview install program as it doesn't happen with other install progs. Picaview still works alright though and that's the main thing. There is a lot to be said for being able to right click on a pic and see what it is without having to open a complete program.
Message edited by califrag on 09-07-2008 at 06:03:22 AM
Reply to califrag
There are 1298 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
