I have a VisionTek GEFORCE 2 GTS 32 MB AGP video card. Are there any known issues running this card in Windows 2000 or in an Asus A7V133 motherboard? Thank you.
I don't run 2k or an A7V, but I do own the card. It uses nVidia's reference design and high quality Infineon ram, so it should be as good as any other GTS card.
The GTS works fine until you load DirectX version 8...don't say I didn't warn you... Check out the latest post for all the ticked off users of that confounded program..you pretty much have the same config as a lot of us have..so, as long as you don't run Direct X 8 you should be fine..
Motivation is half the battle to success..personal intiative completes the process..
