Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > NetGear MR314 wireless router problem - no wireless light ..
Forum Wireless Networking : Wireless General Discussions - NetGear MR314 wireless router problem - no wireless light ..
Archived from groups: alt.internet.wireless (More info?)
My Netgear MR314 wireless router worked fine for about 3 months. All
of a sudden, the wireless connection disappears. Looking at the base
unit, I can see that the wireless light indicator is not showing.
However, everything else works fine. I unplug it and leave it switched
off for an hour, turn it on and it works again.
However, the same thing has happened. And this time rebooting it has
no effect.
Has anybody had this problem?
My setup:
2 x Netgear MA111 USB wireless adapters
1 x Netgear MR314
Win XP
Thanks!
Alex
dinnertan@ya-nospam-hoo.com
Sponsored Links
> no effect.
> My setup:
> 1 x Netgear MR314
> Win XP
> Thanks!
> Alex
Check that the power adapter is not plugged in to a surge protector, and
that it is open to the air for cooling. I have had similar NG device
problems (Linksys as well) caused by a AC adapters that are covered
over, inverted which causes overheating or having an inadequate AC
voltage from a faulty surge protector which also make it run hot.
Q
Reply to Anonymous
> Q
It's currently plugged into a multi socket adapter, with no surge
protector. However, it is placed above my tv, so that could be it.
I've moved it a to cooler shelf, and also upgraded the firmware. The
problem seems to have gone away now.
Thanks!!!
Reply to Anonymous
There are 1142 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
