Tom's Hardware > Forum > Systems > Dell > Inspiron Memory Problem
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi,
I have a Dell Inspiron 600m running XP, and it has a problem with
memory.
It has 2x256 MB SODIMMs (PC2100 DDR). When one SODIMM is installed,
there are no problems.
However, when I install a second SODIMM, the additional memory is
detected, XP starts fine, but then it blue screens (usually
MEMORY_MANAGEMENT error) within 5 minutes. Upon reboot, the bios
encounters a memory error and then adjusts itself automatically to use
only one SODIMM. Reseating the memory causes it to detect the other
SODIMM, and the problem repeats.
I have tried swapping out each of the SODIMMs with another SODIMM that
is compatible with the same result. All three of my SODIMMs work fine
when used by themselves, but it always fails when using a second
SODIMM.
Therefore, I assume that the problem is not with the memory modules,
but rather with memory management on the motherboard. Anyone know how
to go about fixing this type of problem (without installing a new
motherboard)?
Thanks,
-Jeff
Sponsored Links
where did you get the memory?
<jeff.dyck@usask.ca> wrote in message
news:1116343784.106875.28190@g43g2000cwa.googlegroups.com...
> Hi,
> memory.
> SODIMM.
> motherboard)?
> Thanks,
> -Jeff
Reply to BigJim
jeff.dyck@usask.ca wrote:
> Hi,
> memory.
> SODIMM.
> motherboard)?
> Thanks,
> -Jeff
When you tested the memory inidividually, did you try them on each slot?
Have you tried running memtest86 or a similar program for any period
of time?
Reply to Anonymous
If I had to guess you have memory that is not the same you do not mention
where you got the memory.
Check the labels on the memory it is probably different
Wayne
> Hi,
> memory.
> SODIMM.
> motherboard)?
> Thanks,
> -Jeff
Reply to Anonymous
2 of the modules shipped with my Dell and it worked fine for a year and
a half.
The other module, I got from an Ebay seller - it is compatible with the
ones I have (PC2100, 2.5v, non-ECC).
Yup - I rotated them and tried all 3 combinations. Same result for
each.
> Have you tried running memtest86 or a similar program for any period of time?
Yeah - it never throws errors with any one of the modules installed,
but with any two, it throws errors like mad during the third test.
I have 2 Hynix and 1 Samsung, all PC2100, 2.5v, non-ECC. They should be
compatible.
Therefore, it doesn't seem to be a problem with the memory modules.
Any ideas on how to diagnose and solve this problem:
-Dell Inspiron 600m laptop
-works fine with 1 memory module installed
-memory errors occur when there are 2 memory modules installed
-the problem is (almost certainly) not the memory modules
Thanks,
-j
Reply to Anonymous
There are 1135 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 16:28 bilbat won the Motherboards badge
  • 01:00 jayhsyn won the Freshman badge
  • 01:00 nesta13 won the Freshman badge
  • 01:00 petar won the Freshman badge
  • 01:00 sinsear won the Freshman badge
  • 01:00 UnawareAtol won the Uniformed badge
  • 01:00 buryaku won the Uniformed badge
  • 01:00 Redras0324 won the Uniformed badge
  • 01:00 dvdmania won the Uniformed badge
  • 01:00 ugotomega won the Uniformed badge
