S Sageareno Honorable Jan 15, 2013 2 0 10,510 Jan 15, 2013 #1 my laptop only works with the battery in,and pluged in,pull battery out it dies,unplug computer and it dies
Solution mc_creeper Jan 15, 2013 Your battery is depleted. Buy a new battery for your laptop model. Some laptops don't work unless a battery is installed.
mc_creeper Honorable Dec 27, 2012 174 0 10,710 Jan 15, 2013 Solution #2 Your battery is depleted. Buy a new battery for your laptop model. Some laptops don't work unless a battery is installed. Upvote 0 Downvote Solution
S Sageareno Honorable Jan 15, 2013 2 0 10,510 Jan 15, 2013 #3 Thank you very much,somebody said to put the battery in the freezer for 24 hours take out let sit for 2 hours then try,I still have it in freezer,cant wate to try it. Upvote 0 Downvote
B Brett928S2 Champion BANNED Jan 3, 2012 15,316 0 52,960 Feb 23, 2013 #4 Best answer selected by Brett928S2. Upvote 0 Downvote
B Brett928S2 Champion BANNED Jan 3, 2012 15,316 0 52,960 Feb 23, 2013 #5 Hi CLOSING due to age... but please start another thread if you are still having problems , which I will answer promptly... All the best Brett Upvote 0 Downvote
