Hi,
I have emachines / acer e642g
Cpu: AMD P340
Ram: DDR3 1066 4GB
VGA: Ati 5650
hdd: WD blue 500gb
windows 7 x64 ultimate sp1 (with all updates)
So laptop randomly freezes it doesn't matter what are you doing and you have to power it of by holding power button. Temperatures is about 50 C. It even freezes playing solitaire with no other program running. I thought it was hdd cause hdd regenerator found a delay on hdd so i changed it but it's the same. I did fur mark just to see temp it goes about ~75 C. Did Memtest 86+ ran for 8h no errors.
It did had warranty but when i gave them the laptop after the test said there's nothing wrong with it and it's software cause they can't find the problem (they are lazy bums).
So i tried different version of windows 7 x64 ultimate, different drivers (newer, older) nothing helps. Any other suggestions ?
Cpu: AMD P340
Ram: DDR3 1066 4GB
VGA: Ati 5650
hdd: WD blue 500gb
