Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > 2G Ram, system settings..
Forum Windows XP : General Discussion 2G Ram, system settings..
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I just recently upgraded my laptop to 2 gigs of ram. And it is working
fine.
What I was wondering is if there is a setting somewhere, to force
windows to use as much of my ram as possible, before ever using the swap
file?
The reason I say this, is even though I now have so much Ram, windows
is STILL swapping stuff out to my swap file.
can I safely turn the swap file off? or should I?
TIA
Michael
Reply to Anonymous
In news:eZu3FuSlFHA.1204@TK2MSFTNGP12.phx.gbl,
Michael Arends <windows_xp_fans@UGLYSPAMearthlink.net> had this to say:
My reply is at the bottom of your sent message:
> fine.
> swap file?
> TIA
> Michael
You really shouldn't disable the swap file (page file in XP) because it's
likely to cause more errors than it's worth. Using various tweak application
you can force the OS to load a number of files to RAM and if the system has
enough RAM the tweak works fairly well. While you can do this manually if
you wanted it's far easier to get a trial version of XSP from
www.x-setup.net and making your changes with that.
Galen
"But there are always some lunatics about. It would be a dull world
without them."
Sherlock Holmes
Reply to galen
Michael
Read through the article.. http://aumha.org/win5/a/xpvm.php .. it is the
definitive on pagefiles and why you should have one..
Mike Hall
MVP - Windows Shell/User
"Michael Arends" <windows_xp_fans@UGLYSPAMearthlink.net> wrote in message
news:eZu3FuSlFHA.1204@TK2MSFTNGP12.phx.gbl...
> fine.
> file?
> TIA
> Michael
Reply to Anonymous
There are 2111 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 17 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
