G
Guest
Guest
Previously I have been using a Voodoo3 2k agp and had this problem where i am running any benchmark or games, and if the room temp is rather warm(30+), the benchmark or game will automatically exit(Booted out to desktop) after some time. But if i lower the overall roomtemp by even just a few degrees lower this prob does not occur. I think that it may be attributed to the usual vid card overheating so i run down the speed to default and the same thing happened. Then i read an article abt the V32k not running properly even at slightly high room temp even at default speed so i slapped on a heatsink n some ramsinks thinking all is fine but wtf, same old problem.
Thinking that the V32k is kinda old anyway so i scraped whatever pennies i could n got meself a GF2MX400 BUT same problem again-premature exits to desktop. I tried testing various vid cards like GF2 GTS, Radeon and ran evrything at default speed and voltage but all show the same symptoms.
1 thing i noticed is that this problem does not occur for cpu intensive stuff as i managed to run sandra2001 or prime95 for hours without a hitch.
I narrowed down the problem to components overheating related 2 operation of the vid card but ??what??. my case is rather well ventilated with 2 intake n 3 exhaust but maybe i can pinpoint the problem area n slap a heatsink 2 it or add cooling.
Anyone ever had this problem?
This had been botherin me for months now with no practical solution in sight...
Somebody, anybody pls help.Thanks.
My Specs.
KT7(UL Bios)
300W PSU
Duron800 @ 1050
V32k / GFMX2400
SBLive Value
My Specs.
KT7(UL Bios)
300W PSU
Duron800 @ 1050
V32k / GFMX2400
SBLive Value
