Hi everbody!
I have a Chaintech geforce2 gts card. Anyways, it has it's cpu clock set to only 166MHz (should be 200) and memory at 310MHz (should be 333).
I've tried to use NVMax and gtu (or something like that) to change the settings. The problem is that upon reboot, the clock speeds get reset to 166/310...
The programs have options to set the 'apply the settings at startup' and 'change registry values' or something like that but they don't work (;_
Does anyone know how i can more or less permanently change the clock values (that is, so that i don't keep having to change the speeds upon startup)?
luvs and hugs ian
luvs and hugs ian
