Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I recently upgraded to XP on my PC that used to have Windows 98SE. The only
problem I had was that the sound card didn't work, and I determined that it
needed a proper driver for XP to work.
After searching the Internet, and finding some drivers that I thought might
work with the sound card, I downloaded one that I thought would work, but a
major error was encountered, and after that, the cd-rom drive wouldn't work.
Apparently the driver for it was corrupted, because I get a message to that
effect when I try to re-install the cd-rom drive.
I would like to just re-install Windows XP, but how can I do that if the
drive won't run? I put the disk in, but nothing happens. When the PC first
boots up, it recognizes the cd-rom drive, but it doesn't show up in Windows
Explorer as the D: drive.
I tried downloading drivers from some Internet sites, but I get these DOS
programs for installing them, and they never work. (I know very little about
DOS).
Any help in this area would be greatly appreciated.
Does the drive show up in device manager? Click Start/ run/ devmgmt.msc/
ok.Do you have another optical drive? You can set that drive to start first
to boot from the cd in setup /bios. Look in your computer/mother board
manual too se how it's done.
You can also take a look at this.
http://support.microsoft.com/defau [...] 320553#kb1
"aschichler" <aschichler@discussions.microsoft.com> wrote in message
news:11D8E3F6-D00B-47B4-B57C-F701B6B1CAB3@microsoft.com...
> it
> might
> a
> work.
> that
> Windows
> about
> DOS).
