Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I cannot use windows update because the bar at the top will not let me
download active x control, I have reset my security settings to enable all
and the problem is still there. Please help.
Dave
Sponsored Links
Give this a try. In Internet Explorer, from main menu , select Tools ,Internet Options ,
Security Tab. Then click on green icon Trusted Sites/click Sites button.
Look very closely at line that says:
"Require server verification (https:) for all sites in this zone" to *clear* the selection.
(e.g. You want that to be un-checked (un-ticked)).
In the "Add this Web site to the zone:" field, add these entries to list of "Trusted Sites" --
type
http://*.download.windowsupdate.com (click Add)
http://windowsupdate.microsoft.com
http://update.microsoft.com
Click OK. Apply changes to IE browser.
Then re-try Windows Update.
If no joy, go back into IE browser, recheck settings for Active X, so that signed controls are set to enabled.
I presume you did a right-click on message bar, to allow acceptance of Active control.
Do indicate if you are running some added security software utility that blocks or restricts ActiveX.
Maurice N
MVP Windows - Shell / User
> enable all and the problem is still there. Please help.
Reply to Anonymous
I have done everything that you told me to do, and still no joy. What's next?
Dave
> type
> Maurice N
Reply to Dave
What options do I have for getting this problem resolved? I just installed XP
and really want it to work right.
Dave
> Dave
> > type
> > Maurice N
Reply to Dave
You just installed XP. What else did you install on this Windows? An antivirus? which one? Checked its settings to insure they don't block scripts or ActiveX?
Did you install a security program, or firewall? Which one? Check its settings.
Go into Internet Explorer > Internet Options > Security settings. Try resetting the settings back to default.
Maurice N
> installed XP and really want it to work right.
>> What's next? --
>> Dave
Reply to Anonymous
I have no antivirus, no firewall and no security programs and when I set the
settings to default the security settings are higher and I still can't use
autoupdate. I have just reinstalled XP hoping that would fix the problem but
no luck.
What now?
Dave
> Maurice N
> >> What's next? --
> >> Dave
Reply to Dave
Should I call Microsoft? I really want to like XP but if I can't update then
it's no better than ME.
Dave
> no luck.
> What now?
> Dave
> > Maurice N
> > >> What's next? --
> > >> Dave
Reply to Dave
You certainly can call MS.
Maurice N
> update then it's no better than ME.
Reply to Anonymous
You have to have an Antivirus. Go to the local computer store & get one. Do not go into the internet or use email without it.
Click on following link for Windows Update ( or copy and paste it into Internet Explorer browser)
https://update.microsoft.com
Maurice N
> set the settings to default the security settings are higher and I
> still can't use autoupdate. I have just reinstalled XP hoping that
> would fix the problem but no luck.
> What now?
>> its settings.
>> Maurice N
Reply to Anonymous
What about my active x problem? Can anyone help with that? While I appreciate
your suggestions as to my lack of antivirus what about my active x problem???
Dave
> Maurice N
> > What now?
> >> its settings.
> >> Maurice N
Reply to Dave
Dave,
I'm trying to have you get around this problem, for now. Did you click or type in & use the following link to Windows Update
This may just get you the latest controls for Windows Update. Please try & post back.
Maurice N
> appreciate your suggestions as to my lack of antivirus what about my
> active x problem???
>> into Internet Explorer browser) https://update.microsoft.com
>> Maurice N
Reply to Anonymous
Dave,
I still would like for you to try my last suggestion. And then, do this to tweak the pop-up blocker in I.E.-SP2.
From Internet Explorer main menu, select Tools, then Popup blocker, then popup blocker settings.
For address of Web site to allow, type in
*.microsoft.com
Press Add, then press Close. Try Windows Update once more.
HTH
Maurice N
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Active x problems
There are 740 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
