Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Maxtor Hard Drive Problem
Forum Windows XP : Windows XP General Discussion - Maxtor Hard Drive Problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have a hardrive( Maxtor 6Y200P0) wich have got corrupted and bad
segments.(this seme to be a common problem with Maxtor drives)
Im almmost sure this drive have psychical damaged clusters,
cause i have tested alot & alots of tools that should fix this has
failing in repairing this damaged clusters and segments
this includes Maxtor official PoweMax v 1.21, wich fails to complete
the surface test.
i have got an Error Diagnostic Code=de676679
a code with a 8 numeral should indicate that a Maxtor Drive drive is
broken,and is in need of replacement. thats all i know
where should i send this code for a real analyz?, cant find anything on
Maxtor Website,
Another question, there is allso an option to do a Low ore High
level formatation of the drive. I have heard that this could fix
corrupted
segments,
If so,this must only be possible on logical damaged hardrives, not
psycial
damaged drives right? i have waiting with reformatation
cause im unsure what type damage the drive have, and this is my last
alternative to do.? should i do a low/high level formatation anyway?
Any advice is highly appritiated
Kloppstock
Sponsored Links
"Kloppstock" <Kloppstock.1t5dpp@pcbanter.net> wrote in message
news:Kloppstock.1t5dpp@pcbanter.net...
> the surface test.
> Maxtor Website,
> corrupted
> segments,
> psycial
www.maxtor.com click on warranty service on the left. You will have to fill
out a form then they will email you with an rma # and instructions.
Kerry
Reply to Anonymous
There are 540 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
