Archived from groups: alt.internet.wireless (More info?)
I have a wired and wireless network.
All systems are running XP
One system connects to the internet and then shares the internet connection
using Windows ICS tool
The computers connected to the network via wires can see the internet
connection and can connect to the internet
The computer trying to connect to the internet via wireless cannot see the
internet connection - however I can ping the wireless laptop, and the
wireless laptop can ping the system sharing the internet connection, and I
can transfer files between the two
Check the firewall settings in the laptop.
Ron Bandes, CCNP, CTT+, etc.
"Chris Gibbins" <newsgroups@losimagic.net> wrote in message
news:1084722010.4595.0@nnrp-t71-01.news.uk.clara.net...
connection
> Any ideas? thanks
I am running Norton's Firewall on all systems, And i've tried disabling it
on all systems, but the problem remains
"Ron Bandes" <RunderscoreBandes @yah00.com> wrote in message
news:ClMpc.19058$MH.6384836@news4.srv.hcvlny.cv.net...
> connection
the
I
> > Any ideas? thanks
news:1084722010.4595.0@nnrp-t71-01.news.uk.clara.net:
> connection using Windows ICS tool
> the internet connection - however I can ping the wireless laptop, and
> the wireless laptop can ping the system sharing the internet
> connection, and I can transfer files between the two
> Any ideas? thanks
What IP is the wireless computer getting? If it's getting a 169 IP then
the computer is having trouble getting an IP from the DHCP server on the
ICS host machine. The IP will allow the machine to work on the LAN ping
and share files. But the IP will not allow the machine to go the
Internet. This is usually do to a mis-configuration of the NIC.
The TCP/IP stack can be hosed at this point as well still producing the
169 IP condition. You should try using the wire connection on the machine
to see if the stack is not hosed before proceeding further, if the
machine is getting the 169 IP.
Am I correct in assuming you have shared the Internet via two NICs in the
one ICS computer--one wireless and one Ethernet?
If so, that's your problem. Disable the wireless NIC in the ICs computer,
connect the Ethernet NIC to a hub from which connect the other wired
computers and also add a connection to an Accesspoint for wireless
connections.
connection
> Any ideas? thanks
John,
Are you saying to connect the broadband modem, ICS computer, wired clients,
and access point all to the same hub? That would be wrong. The link
between the broadband modem and the ICS computer must be in a different
subnet than the LAN containing clients. An ICS computer always has 2 NICs.
"John" <Me@myhome.net> wrote in message
news:mjQpc.33241$U4.10860@bignews6.bellsouth.net...
> connections.
> connection
the
I
> > Any ideas? thanks
Ron,
Nothing was mentioned about a broadband modem so I assumed, possibly
incorrectly, he had a regular modem connected via serial port. Then he had
another wired computer connected to the ICS comp via an Ethernet NIC and
then also the wireless NIC in the ICS comp. To quote:
"...The computers connected to the network via wires can see the internet
internet connection..."
news2gqc.31710$MH.12408775@news4.srv.hcvlny.cv.net...
> John,
clients,
NICs.
the
computer,
> > connections.
> > connection
> the
and
> I
> > > Any ideas? thanks
