Tom's Hardware > Forum > Deals > Classifieds > 50 inch game has monitor burn how do you fix it?
Forum Deals : Classifieds - 50 inch game has monitor burn how do you fix it?
Archived from groups: rec.games.video.arcade.marketplace (More info?)
I have a 50 inch projection game and there is quite a bit of monitor
burn on it. Does anyone know how to fix this or what parts I need to
replace.
Thanks,
Paul
Sponsored Links
Uhhhh u can't fix it... I never knew of a repair for monitor burn other
than buying a new monitor.
Reply to Anonymous
Paul,
Depending on the model, I think you can replace the Plastic film on the
inside of the screen. My brother-in-law has a Pioneer projection
television that his kids cracked the screen real bad and he was about
to get the film that goes on the inside that actually focuses the beams
into little tiny squares that make up your picture...
Don
NJ
Reply to Anonymous
easy fix... you just put in a whole new monitor...
unfortunatly you're pretty much screwed... the burn in is just that... the
phosphors have been destroyed and there is no hope of fixing them.
burn-in is made even worse on projection TV's as they have to output much
more light then a normal direct view crt would.
"The Duke" <Pknific@gmail.com> wrote in message
news:1123174456.945547.120380@o13g2000cwo.googlegroups.com...
> replace.
> Thanks,
> Paul
Reply to Anonymous
Will a Monitor from a 50 inch tv i buy on ebay work? or are they
differnt. I Know how to fix 19 inch ones but i have never tried to fix
a projection one.
~Paul
Reply to Anonymous
>bit of monitor burn on it
You are SOL as far as the burn goes. My guess is the burn is in the
phospors of the guns and not the projection screen? Cheaper to buy a
new monitor, no?
Kirb
Reply to Anonymous
WITH the power OFF, take a look at the 3 crts inside it. replace the CRTs
that are burnt then it will be fine..
AF
news:1123177363.610519.289380@o13g2000cwo.googlegroups.com...
> a projection one.
> ~Paul
Reply to Anonymous
It depends on the game and how it's connected... is it going to the tv as a
standard TV? something higher resolution?
you'd have to give us a lot more information...
> a projection one.
> ~Paul
Reply to Anonymous
There are 943 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
