G
Guest
Guest
i recently bought a 64mb geforce2 mx 400 card, but i am having trouble with it, and i thought that maybe one of you will know how to make it work. I get pretty good fps with it, between 40 and 60 (in half-life: counterstrike). The problem is that it is jumpy, about every second it lags. my brother says it's from my processor, but i doubt that because it's a 450mhz pIII. today i tried it at 640x480 resolution (again in counterstrike) and it worked about as good as my old card, a 16mb tnt card. It should be able to be running perfect at 1024x768 resolution and higher. I downloaded the latest drivers from the nvidia website, and am completely puzzled as to why it isn't working. I've tried it in openGL, direct3D, and even software with the same results
thanks
thanks
