Nail.exe adware problem
Forum Windows XP : Windows XP General Discussion - Nail.exe adware problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Yesterday, I was downloading a "free" screensaver and began receiving
adware. I stopped the download and began checking for problems. Adaware
found many problems, which it fixed (it says).
My problem is that somehow this adware has made all the files in the XP Pro
c:\winnt disappear from view. Computer still works fine, so they must be
hidden by some other means.
I found this line in HijackThis that was objectionable.
F2 - REG:system.ini: Shell=Explorer.exe c:\WINDOWS\Nail.exe
It couldn't be fixed because no files can be seen in the C:\Winnt directory.
Norton can not scan a directory with no files, etc., and I can't delete any
files for the same reason. The only file showing in the folder is
c:\winnt\system32\spllo\PRTPROCS\W32X86\hpprn02.dll (may be a printer
driver).
I went into the registry and deleted this key and still no luck, although it
stopped the automatic addition of a new file to be included in startup with
the "stop process" of an unknown .exe in the taskmanager.
So... I need to know how to restore the files to "not hidden". And, if
anyone has any ideas regarding removal of this adware, I'd be most grateful.
Tom
Sponsored Links
Hi
There 'may' be a Registry entry:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
(Shell=Explorer.exe C:\WINDOWS\Nail.exe)
If you find that entry delete it, but only that one entry. Make sure that
you backup the Registry first.
Will Denny
MS-MVP Windows Shell/User
Please reply to the News Groups
"Tom Landon" <mdeanhouston@sbcglobal.net> wrote in message
news:OZGXZ3bmFHA.3544@TK2MSFTNGP15.phx.gbl...
> Pro c:\winnt disappear from view. Computer still works fine, so they must
> be hidden by some other means.
> directory. Norton can not scan a directory with no files, etc., and I
> can't delete any files for the same reason. The only file showing in the
> folder is c:\winnt\system32\spllo\PRTPROCS\W32X86\hpprn02.dll (may be a
> printer driver).
> it stopped the automatic addition of a new file to be included in startup
> with the "stop process" of an unknown .exe in the taskmanager.
> grateful.
> Tom
Reply to Anonymous
Please download ewido security suite it is a free version of the program.
http://www.pcbutts1.com/downloads/ewidosetup.exe
Install ewido security suite
When installing, under "Additional Options" uncheck..
Install background guard
Install scan via context menu
Launch ewido, there should be an icon on your desktop, double-click it.
The program will now open to the main screen.
When you run ewido for the first time, you will get a warning "Database
could not be found!". Click OK. We will fix this in a moment.
You will need to update ewido to the latest definition files.
On the left hand side of the main screen click update.
Then click on Start Update.
The update will start and a progress bar will show the updates being
installed.
(the status bar at the bottom will display "Update successful" )
Exit ewido. DO NOT SCAN YET.
Download CCleaner and install it, but do not run it yet.
http://www.pcbutts1.com/downloads/ccsetup122.exe
Please download this file: Revised Installer for the Nailfix Utility
http://www.pcbutts1.com/downloads/nailfix1.exe
Save it to your desktop.
DO NOT RUN IT YET.
Next, please reboot your computer in SafeMode by doing the following:
Restart your computer.After hearing your computer beep once during startup,
but before the Windows icon appears, press F8.Instead of Windows loading as
normal, a menu should appear
Select the first option, to run Windows in Safe Mode.
Once in Safe Mode, please double-click on nailfix.exe.
Click "Next" in the setup
Make sure "Run Nailfix" is checked and click "Finish".
Your desktop and icons will disappear and reappear, and a window should open
and close very quickly --- this is normal.
Now open ewido and do a scan of your system.
Click on scanner
Click on Complete System Scan and the scan will begin.
NOTE: During some scans with ewido it is finding cases of false positives.**
You will need to step through the process of cleaning files one-by-one.
If ewido detects a file you KNOW to be legitimate, select none as the
action.
DO NOT select "Perform action on all infections"
If you are unsure of any entry found select none for now as the action.
Once the scan has completed, there will be a button located on the bottom of
the screen named Save report
Click Save report.
Save the report .txt file to your desktop or a location where you can find
it easily.
**(Ewido for example has been flagging parts of AVG Anti-Virus, pcAnywhere
and the game "Risk" )
Now run HijackThis, click Scan, and place a checkmark next to each of the
following items:
F2 - REG:system.ini: Shell=Explorer.exe C:\WINDOWS\Nail.exe
Close all open windows except for HJT, then click the Fix Checked button.
Close HJT.
Locate and delete the following File
C:\WINDOWS\Nail.exe
Now run CCleaner
Uncheck "Cookies" under "Internet Explorer".
If running Firefox: click on the "Applications" tab and uncheck "Cookies"
under "Firefox".
Click on Run Cleaner in the lower right-hand corner. This can take quite a
while to run.
Finally, restart your computer in normal mode and please post a new
HijackThis log, as well as the report log from the Ewido scan by using Add
Reply.
The best live web video on the internet http://www.seedsv.com/webdemo.htm
NEW Embedded system W/Linux. We now sell DVR cards.
See it all at http://www.seedsv.com/products.htm
Sharpvision simply the best http://www.seedsv.com
> printer driver).
> grateful.
> Tom
Reply to Anonymous
i'm having the same problem that's why i was asking about reformatting the c
drive...these adaware programs are nearly impossible to get rid of...won't
let you run live update with nortons, ms antispyware finds them removes them,
then they are back, now they did somethign to safe mode, won't boot to safe
mode!!!...so i figure is to start from square one again...
> driver).
> Tom
Reply to Anonymous
- 0 +
Try running spybot from http://www.safer-networking.org/en/index.html it
looks like it is part of "Aurora" spyware. If you google for nail.exe there
are many suggestions.
Neil
> printer driver).
> grateful.
> Tom
Reply to Neil
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Nail.exe adware problem
There are 732 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
