Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Manually set Restore point problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I am trying to manually set a restore point and I get a message in Win
Xp Professional, "unable to set a restore point. you must restart the
computer and try again".. I restart the computer and then it does the
same thing. I successfully created a restore point before doing windows
update. This started happening after the updates were installed. How
can I get this feature to work again? I checked and it's not turned off.
Thanks in advance.
Sponsored Links
Clear all your restore points, turn off system restore and reboot. Turn
system restore on again and set your restore point.
"Robert Tudor" <rtudor@bellatlantic.net> wrote in message
news:A6SIe.2949$sv.1948@trnddc08...
>I am trying to manually set a restore point and I get a message in Win Xp
>update. This started happening after the updates were installed. How can
> Thanks in advance.
Reply to Jim
Check the free space on your drives. System Restore needs to see 200MB of free space. A lesser amount causes to not set automatic restore points.
Try this. Select RUN option from main Start menus. Type in
SERVICES.MSC <enter-key>
Review the line for System Restore Service. It needs to show Started under the Status column, with Startup Type of Automatic.
If need be, while in the Services control section, you can Start the service, or even stop & restart the service.
Maurice N
MVP Windows - Shell / User
> the same thing. I successfully created a restore point before doing
> windows update. This started happening after the updates were
> installed. How can I get this feature to work again? I checked and
> Thanks in advance.
Reply to Anonymous
Thanks, will try that...
Reply to Anonymous
There are 1142 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
