Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi, please help me with this problem,
In a not updated Version of Windows XP you can run (Start-run) "start" command at the Run dialog just typing it, when you update windows and write the same "start" into Run dialog Windows shows a error message >
Windows cannot find `start`. Make sure you typed the name correctly, and then try again. To search for the file, click the Start button, and then click Search.
If you are in CMD the `start` command works fine but the problem is the in Run dialog windows doesn’t recognize it ?
Anybody know how to fix this or what windows update not to install ?
Please Help
Thanks in advance
Zlatin Boykov
Hmm.. "start" is one of the *internal* commands of command prompt, it is not
a separate executable that you can launch using run, it doesn't exists as a
file, it's built-in, you must be in command prompt shell to launch it..
There are many other built-in commands.
"zlatin" <zlatin.1tbv1n@pcbanter.net> wrote in message
news:zlatin.1tbv1n@pcbanter.net...
> then click Search.
> in Run dialog windows doesn't recognize it ?
> Please Help
> Thanks in advance
> Zlatin Boykov
> zlatin
