Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > start cmd command problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi, please help me with this problem,
In a not updated Version of Windows XP you can run (Start-run) "start"
command at the Run dialog just typing it, when you update windows and
write the same "start" into Run dialog Windows shows a error message
Windows cannot find `start`. Make sure you typed the name correctly,
and then try again. To search for the file, click the Start button, and
then click Search.
If you are in CMD the `start` command works fine but the problem is the
in Run dialog windows doesn’t recognize it ?
Anybody know how to fix this or what windows update not to install ?
Please Help
Thanks in advance
Zlatin Boykov
zlatin
Sponsored Links
start is not necessary in the run line, but if you want a run command that does it, try: CMD /c start /MAX notepad
Mark L. Ferguson
FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
"zlatin" <zlatin.1tbv1o@pcbanter.net> wrote in message news:zlatin.1tbv1o@pcbanter.net...
> then click Search.
> in Run dialog windows doesn't recognize it ?
> Please Help
> Thanks in advance
> Zlatin Boykov
> zlatin
Reply to Anonymous
There are 1196 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
