What is wrong with my netbook monitor
jessica2442
4
It is an HP product # XT981UT is that the right #? When you tap on the screen lightly the colored lines get darker and lighter, but you can still see some of the screen thru the colored lines
Yes, the unknown secret about a screen saver is that it creates a force field around the screen itself. It is so strong that it can survive the impact of a 50 calibre armor piercing bullet which has a velocity faster than the speed of sound. Too bad it doesn't extend beyond the screen though so while the screen itself may survive the impact, the shockwave will destroy the rest of the laptop.
Hi :)
The shooter could always use Frangible ammo...
All the best Brett :)
