Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > start cmd command problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Dear Mark, the problem is that I have a program that uses the start
command, and when I thy to use my program in updated windows it dosnt
work! I need to find a way to use the start command directly.
Thanks for your help
Zlatin Boykov
Mark L. Ferguson Wrote:
> start is not necessary in the run line, but if you want a run command
> that does it, try: CMD /c start /MAX notepad
> Mark L. Ferguson
> FAQ for Windows Antispy
> http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
> "zlatin" zlatin.1tbv1o@pcbanter.net wrote in message
> news:zlatin.1tbv1o@pcbanter.net...-
> Hi, please help me with this problem,
> In a not updated Version of Windows XP you can run (Start-run)
> "start"
> command at the Run dialog just typing it, when you update windows and
> write the same "start" into Run dialog Windows shows a error message-
> Windows cannot find `start`. Make sure you typed the name correctly,
> and then try again. To search for the file, click the Start button,
> and
> then click Search.
> If you are in CMD the `start` command works fine but the problem is
> the
> in Run dialog windows doesn't recognize it ?
> Anybody know how to fix this or what windows update not to install ?
> Please Help
> Thanks in advance
> Zlatin Boykov
> zlatin-
zlatin
Sponsored Links
Try Compatibility mode.
HOW TO Use the Program Compatibility Wizard (Q301911) Go to: http://support.microsoft.com/?kbid=301911
Mark L. Ferguson
FAQ for Windows Antispy http://www.geocities.com/marfer_mvp/FAQ_MSantispy.htm
"zlatin" <zlatin.1tcsdt@pcbanter.net> wrote in message news:zlatin.1tcsdt@pcbanter.net...
> Zlatin Boykov
>> Mark L. Ferguson
>> "start"
>> and
>> then click Search.
>> the
>> Please Help
>> Thanks in advance
>> Zlatin Boykov
>> zlatin-
> zlatin
Reply to Anonymous
There are 1197 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
