Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Yes , it is an internal program, but in an none updated version of
windows it works, the problem is that I have a program that uses start
command directly, and now this program dosnt work in an updated windows
XP version,
Somebody knows hot to configure the uses of the built-in commands or
something similar.
Thanks
Zlatin Boykov
Mak Wrote:
> Hmm.. "start" is one of the *internal* commands of command prompt, it is
> not
> a separate executable that you can launch using run, it doesn't exists
> as a
> file, it's built-in, you must be in command prompt shell to launch
> it..
> There are many other built-in commands.
