Archived from groups: microsoft.public.windowsxp.help_and_support (
More info?)
I dunno what you're problem is for certain.
scannow has some support error bulletins.
scanonce doesn't.
"JohnFL" <JohnFL.1tf3pv@pcbanter.net> wrote in message
news:JohnFL.1tf3pv@pcbanter.net...
> First an explanation of my system.... I am running Windows XP Home, with
> service pack 2, with a Pentium P4 3.0, with 1 gig of memory. I have
> asked this question before on another forum but never have gotten a
> good answer. I have a system that is running correctly. Once a week i
> do a series of things, like cleaning the registry with a good registry
> program, doing a windows "disk cleanup", and then using diskeeper to
> defrag the disk. All of this works great and presents no problems. One
> of the other things i like to do when i do all these things, is to do a
> "sfc /scannow", just to be sure that no system files have been
> corrupted. BUT here is where the problem begins. Whenever i do the sfc
> /scannow, it goes through the entire checkup routine that sfc does, and
> updates the files that need updating ( i guess ). After the sfc /scannow
> has completed, i then do a reboot. But when i reboot and it comes onto
> the windows screen where the 3 little dots show the loading
> proceedures, it STOPS and reboots. In other words, the drive becomes
> unusable. I have to resort to doing a casperXP (ghosting program ),
> from another drive ( where i have a mirror image of my drive C ), to
> get my machine to run properly again. What in the world could the sfc
> program be writing to my hard drive, that would cause it to crash? I
> have washed the XP Home cd, but that made no difference. I looked at it
> closely and there appear to be no scratches on the cd. I have XP Pro for
> another machine, but i dont think i can take the i386 files off of it to
> do an sfc /scannow on my XP Home machine. So what are my options? Should
> i borrow someone else's XP Home disk and see if theirs works? Or am i in
> a situation where i better not use sfc /scannow? Also, does anyone know
> if i can have my XP Home cd replaced by MicroSoft, if infact that is
> what the problem is?
> JohnFL
