Tom's Hardware > Forum > Systems > Dell > Problems With Dell Truemobile wireless Router and 1300 Wir..
Forum Systems : Dell - Problems With Dell Truemobile wireless Router and 1300 Wir..
Archived from groups: alt.sys.pc-clone.dell (More info?)
I'm using a DSL connection to Dell Truemobile wireless router, 2300 firmware
1/04 rj45 connection to XP Pro PC and
and trying to make a wirelss connection to 1200 wireless nic in a W2K Pro
notebook. ipconfig on xp pro pc connected to router w/ rj45 cable show a
static ip address 192.168.2.2, subnet 255.255.255.0.default configuration
for wireless notebook shows dhcp enabled 169.254.225.170 using subnet
255.255.0.0. wep 13 characters is enabled on router. I don't remeber
password to access advanced settings for router. I believe in router
advanced settings I can set subnet and dhcp ip address.\
Mike
Sponsored Links
you will probably need to reset the router to factory default then read the
instructions carefully so you can at least get a basic understanding of
what the numbers in an IP address means.
I always strongly suggest NOT using DHCP with a wireless router as you can
choose the 10.X .X.X subnet rather than 192. By using a static address such
as 10.45.34.23 for your router with a subnet mask of 255.255.255 a person
would need to find what address your router was in order to use your
network!
Wayne
"Mike" <wxyz09@yahoo.com> wrote in message
news:Z5wme.3991$vK5.1341@trnddc03...
> firmware 1/04 rj45 connection to XP Pro PC and
> configuration for wireless notebook shows dhcp enabled 169.254.225.170
> using subnet 255.255.0.0. wep 13 characters is enabled on router. I
> don't remeber password to access advanced settings for router. I believe
> in router advanced settings I can set subnet and dhcp ip address.\
> Mike
Reply to Anonymous
I know what the numbers mean but I need toget into the router's advanced
settings to
change them. Good point about using a differewnt subnet and different ip
address series.
Mike]
"wayne" <komon@dgdg.sss> wrote in message
news:Rfqdnb4kLqrblgbfRVn-ig@comcast.com...
> the instructions carefully so you can at least get a basic understanding
> of what the numbers in an IP address means.
> such as 10.45.34.23 for your router with a subnet mask of 255.255.255 a
> person would need to find what address your router was in order to use
> your network!
> Wayne
>> Mike
Reply to Mike
There are 550 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
