Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > power schemes missing?
Forum Windows XP : General Discussion power schemes missing?
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi everyone, I am not sure how this happened, but it did anyway. During my
problem with system restore, I created my own power scheme called test. I
have noticed that I am missing some power schemes now when I try to access
them using the power options choice on control panel. I am missing "always
on" "presentation" "minimal power management" and "max battery".
I don't know why they don't appear in the drop down menu under power schemes
as "home/office" and "portable/laptop" and my "test" schemes are there.
I have found these schemes exist in my registry in several locations by
typing "powercfg" in the registry editor.
Hopefully someone will know how to restore them. Is there an *.inf file to
right click to reinstall? I found a bunch, just not sure which one it might
be. Thanks for any help.
Reply to Anonymous
> anyway. During my problem with system restore, I created my
> own power scheme called test. I have noticed that I am
> missing some power schemes now when I try to access them
> missing "always on" "presentation" "minimal power
> under power schemes as "home/office" and "portable/laptop"
> locations by typing "powercfg" in the registry editor.
> *.inf file to right click to reinstall? I found a bunch,
> just not sure which one it might be. Thanks for any help.
You might want to download and run the registry fix on line
204, left hand column, Restore Power Schemes/Configurations:
http://www.kellys-korner-xp.com/xp_tweaks.htm
Hopefully, that will correct the problem.
Nepatsfan
Reply to Anonymous
> Nepatsfan
Let's try that again:
204, right hand column, Restore Power Schemes/Configurations:
Sorry for the confusion
Nepatsfan
Reply to Anonymous
Thank you for the link. That is a great site, just so many links, makes me
dizzy. The script worked, and power is back to normal. Thanks.
Eric
"Nepatsfan" <nepatsfan@SBXXXIX.com> wrote in message
news:9e-dnU4ANuiW9WrfRVn-jA@comcast.com...
>> Nepatsfan
> You might want to download and run the registry fix on line 204, right
> Nepatsfan
Reply to Anonymous
> links, makes me dizzy. The script worked, and power is back
> to normal. Thanks. Eric
Glad to hear you've got that problem fixed.
You might want to add that site to your favorites. The next
time Windows starts acting cranky, there's a pretty good
possibility that Kelly's got the solution.
Kelly's registry edits for Windows XP
Windows XP from A to Z
http://www.kellys-korner-xp.com/xp_abc.htm
Troubleshooting Windows XP
http://www.kellys-korner-xp.com/xp.htm
Nepatsfan
>>>> my own power scheme called test. I have noticed that I am
>>>> an *.inf file to right click to reinstall? I found a
>>>> bunch, just not sure which one it might be. Thanks for
>>>> any help.
>>> Nepatsfan
>> Nepatsfan
Reply to Anonymous
There are 2311 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Windows Xp Blue Screen
By nhasian, 16 hours ago:
looks like the problem was caused by the nvidia display driver or the gpu itself. try...
Best offers
Top experts
