print using 'ctrl+p' wont work
  • Microsoft
  • Windows XP
Last response: in Windows XP
Anonymous
August 9, 2005 3:28:42 PM
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
on a new machine with an xp pro upgrade over the top of my old W98, this
good old keyboard shortcut no longer works. Everything else seems to still
work ok (ctrl + c,v,x etc) Why, oh why?
More about : print ctrl wont work
Anonymous
August 9, 2005 3:28:43 PM
It should work irregardless of the upgrade path. Providing you have a print device & are in a Windows-friendly program with the print option. I might suggest that you check on your printer's driver.
Maurice N
MVP Windows - Shell / User
> this good old keyboard shortcut no longer works. Everything else
> seems to still work ok (ctrl + c,v,x etc) Why, oh why?
Anonymous
August 9, 2005 8:45:21 PM
actually it was more a clean install with the 98 disk in hand for the
'proof'.
I just installed latest drivers but still no good ....no ctrl+p in any
applications. ....seems v odd. Any clues?
Anonymous
August 9, 2005 8:45:22 PM
Davo,
Yes, extremely odd. Do a quick check to see that the Print Spooler service is running (and not disabled or stopped).
From Start menu, select RUN, then type in
msconfig <Enter-key>
Click on the Services Tab. Make sure the Print Spooler has a check mark & shows status of Running. If not running, check it to enable, apply, and restart Windows.
From RUN option
services.msc <Enter-key>
Scroll down list of services. Print Spooler service should read Status = Started , Startup type = Automatic.
If it already shows this, you may try Stopping , then Restart-ing the service to see if it makes a difference.
Maurice N
> 'proof'.
Anonymous
August 10, 2005 1:11:34 AM
thanks Maurice
just tried all that....no change
Anonymous
August 10, 2005 1:26:59 AM
Maurice
well I polished up my google search and found this solution listed
first....and it has worked!
There are a number of postings in the archive about CTRL P not working in
XP. This may be of some interest.
I have a 915P board that uses high definition audio. I've discovered that
this registry entry is the culprit:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
"Cmaudio"="RunDll32 cmicnfg.cpl,CMICtrlWnd"
REMing the entry thus:
"Cmaudio"="REM RunDll32 cmicnfg.cpl,CMICtrlWnd"
cured the problem on my machine.
Anonymous
August 10, 2005 1:27:00 AM
Bravo to you. Thanks for posting back. Wonders never cease.
Maurice N
davo wrote:
> Maurice
> working in XP. This may be of some interest.
> that this registry entry is the culprit:
