problem appeared after sp2 laptop
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I have a problem after I upgraded to sp2. I can run IE but other programs
flat out will not run. The icon changes like it wants to start but then it
goes back to normal idle state. The odd bit is I can open previously made
files like .doc to open word but I can't directly open it. Any ideas would be
much apprectiated. Oh problem exists in safe mode and can't run add remove in
control panel or anything in control panel or even calc in run dialog box.
3 answers Last reply
More about problem appeared laptop
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Hi,
    I'm getting the same type of issues. I tried to open the system restore,
    but nothing happens or a blank system restore screen opens up. I have scanned
    for virus, but found nothing. IE opens up for me, but not everything works
    within IE. I hope someone can help us out.
  2. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    laptopprob,
    Since you didn't give us the make/model of laptop I'll assume it's
    driver related problems your seeing.
    Go to Control Panel, Add/Remove Programs, Show Updates, then uninstall
    SP2. Then truck off to your laptop manufacturers website. Look for
    updated bios & drivers. Also run a complete system scan for spyware,
    viruses, ect.
    Defrag hard drive after running disk clean-up.
    Reboot, and try the SP2 update once more.
    Best,
    Treeman
    Treeman
    Treeman's Profile: http://www.msusenet.com/member.php?userid=1260
    View this thread: http://www.msusenet.com/t-1870966841
  3. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Alrighty, finally got to uninstall through microsofts help and a run command
    they had me use so I'll try updating and all that stuff and whatever they
    suggest also. Thanks for the input
    "Treeman" wrote:
    > laptopprob,
    > viruses, ect.
    > Best,
    > Treeman
    > Treeman
Control Panel Laptops Windows XP
