Problem with the monitor
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi, ive got a problem with the computer, it turns on does the initializing
windows .... and then the image goes black... and it keeps like that... what
can i do??
please help me, im soo bad with computers
3 answers Last reply
More about problem monitor
  1. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    Borrow a monitor and swap it with yours to verify it's bad. If you get the
    same results then your video card or built-in video sub-system is bad.
    "Cristina" <salascris@yahoo.com> wrote in message
    news:F3AD3E34-F06D-4D52-8294-46380EEB695D@microsoft.com...
    > what
    > can i do??
  2. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    ok, ill try that, just one more thing, i think it does works, cos it starts
    showing the windows logo, and then it goes blank, but ill verify it right
    now...
    thank you so much
    > > what
    > > can i do??
  3. Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
    news:79B2C694-095D-4787-A61B-7DC94B6EDA96@microsoft.com...
    > starts
    > now...
    > thank you so much
    Another thing - If you start in Safe Mode (press F8 as the system starts)
    does the monitor display properly?
    If so, the monitor settings may be out of range. If that's the case, go
    to Control Panel, System, Hardware, Device Manager, locate the Monitors
    section and expand it. Select the monitor, right-click and choose Remove.
    Say OK. On restart, the system should re-detect and re-install the monitor
    to a default setting, probably 800x600 and 60Hz refresh. Reset this as
    desired, to something supported by the monitor.
    HTH
    -pk
    >> the
    >> > initializing
    >> > what
    >> > can i do??
Support Monitors Microsoft Windows XP
