I *think* it's a heat problem
  • Graphics Cards
  • Graphics
Anonymous
a b U Graphics card
August 26, 2001 6:17:36 AM
Hi there.
Just picked up my Athlon 1.4 today. I've got an Asus 8200 Geforce 3 in it, and when I tried to run 3DMark 2001, it freezes. When I run the benchmark I get to the first Dragothic benchmark (and it freezes at close to the same place each time, but not exactly the same). When I ran the demo I got to the bit where it's got the pretty trees. I rebooted as fast as I could to check the temps (using the SmartDoctor utility that comes with the card) and it showed ~55 degrees celsius GPU temperature (which is about the same as when it was idle - could be cooling down while I reboot...).
Is this a heat problem? Is this a graphics card problem? Any help would be... well... helpful! =)
Thanks in advance,
Jeff
by the way, I was running this under Windows 98. I'm about to try it under Win2k. If the results are different I'll post here.
More about : heat problem
Anonymous
a b U Graphics card
August 26, 2001 6:28:36 AM
Okay, I just finished running it under Win2k. I did get farther (to the first nature benchmark), but it did freeze. It's not responding at all (no ctrl-alt-delete, power button does nothing).
Agh! I just bought this machine - didn't think heat would be a problem _out_of_the_box_.
Still looking for your thoughts.
Jeff
Anonymous
a b U Graphics card
August 26, 2001 6:33:42 AM
... In my Asus Information panel, I am surprised to see
BUS Type: AGP 4X (Current Rate: Off)
all the time. Anybody know what's going on here?
I have an MSI K7T266Pro-R motherboard.
Jeff
Anonymous
a b U Graphics card
August 26, 2001 8:24:39 AM
Nevermind. I just installed the VIA drivers and everything's hunky-dorey. My bad! =)
Jeff
