Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > NTLDR missing after full system recovery with xp built
Forum Windows XP : Windows XP General Discussion - NTLDR missing after full system recovery with xp built
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Please somone help !!! I just recently tried to do a Full system
recovery on
xp.
According to HP i dont need recovery discs as its allready in the
partition memory..
But all i get is a prompt asking me to insert the recovery disc after
about an hour..
so coz i hav’nt got a disk i turned the pc off..
Now all i get is NTLDR MISSING
PRESS CTRL ALT DEL TO RESTART
and this just keeps happening..
any ideas anyone
Posted using the http://www.windowsforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.windowsforumz.com/Help- [...] 06637.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.windowsforumz.com/eform.php?p=1348551
Sponsored Links
If there is no recovery disk then one must assume there is a separate
(probably hidden) partition used for that purpose.
Are you following HP's documented recovery procedure? It's possible
that there is a BIOS entry that needs to be changed in order for
recovery to take place. Check your documentation carefully, and if that
fails to produce a fruitful answer I'd contact HP - unless somebody
here has a similar computer and can help.
Reply to Anonymous
Hi, I am having almost the same problem. Except that mine was caused because the sys recovery did not recognize my 2nd boot disk/DVD. I ended up shutting down the computer and now I just get that NTLDR message. Can you please tell me how you resolved the problem?
Reply to azulsirena88
i also have almost the same problem. im about to reformat my hp laptop coz theres a virus on it my norton anti virus is not scanning anymore so i tried to reformat my laptop using system recovery or recovery manager but when i start pressing it my laptop restarted and it says NTLDR IS MISSING press ctrl + alt+ delete to restart and nothing happens. how can i find the NTLDR or how can i solve this problem? i dnt have windows installion cd when i but it coz they say its on partition recovery.
Reply to Anonymous
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
