NEED SERIOUS HELP!
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I just had to do a complete system restore and after that when I am
downloading anything I keep getting some message popping up, supposedly from
Microsoft, telling me to clean my registry and giving me a website to go to,
but it is always a different website. What is this about???
More about : question
It's a scam. Don't fall for it. When you see a window like that pop up, it's
best not to click anywhere on it. Instead, press CTRL+ALT+DEL to start the
Task Manager. Go to the Applications tab, find the name of the windows, and
"End Task" it.
When you did your "complete system restore" did you remember to visit
Windows Update? Service Pack 2 has a pop-up blocker.
Ted Zieglar
"You can do it if you try."
"hadassahrose505" <hadassahrose505@discussions.microsoft.com> wrote in
message news:315A9C3D-267A-49DB-A5E5-07177F1B4B61@microsoft.com...
from
to,
Thanks so much! I figured it was a scam. I just did download Service Pack 2
and the problem seems to be gone now :)
> "End Task" it.
> Ted Zieglar
> from
> to,
> Pack 2 and the problem seems to be gone now :)
Thats because SP2 has the firewall enabled by default.
Mike Pawlak
Not a prob. just disregard. you pick up a lot of that stuff at porn sites.
in the future, just be more careful which sites you visit. plus your parents
are going to catch you one of these days, and then your in deep do-do.
Ask the community
