I have just upgraded my machine to the following specs:
A7N8X Deluxe (2.0) Motherboard Athlon XP2500 (Barton)
2x Seagate 80Gb Serial ATA Hard Disks Set up as a Striped Array using the utility built into the motherboard.
I have an XP Home OEM CD and It does not detect the Hard Drive (which I assume is now considered as one 160GB drive with the RAID setup) and it doesn't want to install.
Do I need to partition the Hard drive?
I tried with Fdisk but it misreads the size and when I tried anyway it still didn't work.
Can I use FAT32 or should I use NTFS?
What program can I use to set it up?
Help!!! I want to play on my new computer!
I'm also upgrading a friend to the same spec but he'll have Win98SE, will the process be the same?
Thanks
James
Thanks
James
