Solved
Toshiba Satellite Display Problem
Owner of Toshiba Satellite P7755-57215.
Everything is up to date, did a BIOS upgrade after seeing this prolem.
4 inch band of vertical white lines in center of screen at ALL TIMES. Some time of display disfunction.
All I have done at this point was make sure the BIOS was up to date because I am of the understanding the the video cards and built into the CPU in these models.
I have a screenshot if you need a clearer picture of what I'm talking about.
ANy help appreciated, whats the fix? THanks guys
5 answers Last reply Best Answer
More about toshiba satellite display problem
  1. Hi :)
    If those bands are there when you start the machine (dos screens) its NEW screen time...
    All the best Brett :)
  2. Yeah, the vertical transparent lines 4 inch wide in the center of screen show up right when you turn on the machine and see BIOS screen ...
    Really? NO Fix?????
    Has to be something I can do ...
  3. Best answer
    Really? NO Fix?????
    Hi :)
    ONLY two choices... use an EXTERNAL screen plugged into VGA socket, or NEW screen... its NOT repairable...
  4. Thank you SIR. :]
    God bless.
  5. Best answer selected by Brett928S2.
BIOS Toshiba Laptops Displays
