Toshiba - No sound / broken volume dial
Hi Guys,
My volume dial has fell inside my laptop at the front and now the volume isn't working on my laptop, I tried using the volume control next to the clock on the task bar but it won't work.
Does anyone have any suggestions?
3 answers Last reply
More about toshiba sound broken volume dial
  1. Hi :)
    The software control SHOULD STILL work are you getting ANY sound ?
    All the best Brett :)
  2. Thanks Brett, there is no sound coming from the laptop since the dial fell inside. I have tried using the volume control on the desktop, tried device manager uninstalling and re-installing but nothing is working at all. It says the device is working fine but nothing
  3. Hi :)
    To be honest it would cost a LOT of labour to repair, so just get a USB sound dongle to plug in...very very cheap under £10...
Laptops Toshiba
