G
Guest
Guest
Hi guys,
I just assembled a new system, p4-1.5ghz, KOB 850 FSX m/b (mercury) , 256 rdram, geforce 2 mx. The problem is, when i plugged in my geforce 2 on the mainboard, the fan spun for a while, but there wasn't any signal on my monitor. so i powered the system down, and turned it on again. To my horror, the GPU fan isn't spinning anymore! and still there wasn't any signal. I tried the card on my old system, at first it didn't work, but after several tries it works. Any idea why this happens..? seems to work at random...
BTW, I've an old Graphic Blaster (AGP) card which i previously tried on the new P4 board. The connector pins are the other way round ( see below )
'=' denotes AGP port
'-' denotes card connector pin
So i inverted the card and pluged it the OTHER way round , get what i mean? and i plugged the monitor cable in, which went into the casing .. I know that's silly.. but just a try. I wonder if I burnt the AGP port by doing that.. which causes my new Geforce 2 not to work.
Thanks a million, will appreciate if some advice is given.
Cheers,
Damian
Cheers,
Damian
