I have a HUGE PROBLEM.
ok. its like this.
I'm working with a 120GB Hard drive, devided in to 2 partitions, both NTFS, one for system (windows, program files ect.) and one for files (mp3's, videos, documents..)
3 hours ago i wanted to reblast my pc, it was working kind of slow and had too much stuff installed on it.. and it was time for a fresh start. i moved everything immportant to the second partition and rebooted from the windowsXP cdrom. i install the OS on partition one!
everything went great. windows was up and running in no time, and i even started installing my usual software on it.
while i was doing that, i went to my 2nd partition to see all the data is still intact, and it was. but wierd enough, there was an ntldr file there.
"ntldr?? why?? this is not the master partition? "
i thought to myself
"must be the remains from the old OS, better delete it"
and i deleted it!
of course when i rebooted windows didnt find the ntldr and wouldnt load.
ok, i thought, lets just go in the windows CDrom and use FixMBR,
did it, didnt work, so i tried, fixboot C:.
didnt work
Fixboot D:
didnt work
but not only did it not work!!
it made the D: drive (the 2nd partition where all my VERY IMPORTANT DOCUMENTS are INACCASABLE!
i just hooked up an old 40g hard drive just to see if i can access the other hard drive, and i sure can access the first partition, but when i try to access the 2nd one, i get the old "the disk is not formatted, would you like to format now?" massage.
please help, i am about to kill myself soon if i don't get an answer. I'm sure the data is still there. its just a matter of restoring the boot record or something.
please.
help.
thank you.
~ forgive my stupid questions ~
ok. its like this.
i thought to myself
and i deleted it!
didnt work
Fixboot D:
didnt work
please.
help.
thank you.
