Tom's Hardware > Forum > Applications > Multimedia > Picture problem
When playing DVDs on my dvd rom drivethe display only seems to show the middle of the picture and not the edges. For example a image of somebodts whole face only shows the nose area. This also applies to .wav and mpegs images. These images are fine on other machines and it doesnt matter what software/programs i use. Can anybody please help me out here
<P ID="edit"><FONT SIZE=-1><EM>Edited by JTS on 11/12/03 11:29 AM.</EM></FONT></P>
Sponsored Links
Just a guess here.
But all software pograms will use the codecs, or dll files
located in your windows directory. So it would seem that you
will need to uninstall all your codecs or just the ones giving you problems. Search for Nimo codec pack 5 on the internet, download and install it, it should fix your problem. Also try uninstalling and installing the latest DirectX,
hope this helps
Opel Superboss, now that was a car!<P ID="edit"><FONT SIZE=-1><EM>Edited by superboss on 11/26/03 08:41 AM.</EM></FONT></P>
Reply to superboss
i have sine found the solution to my problem. It involved resetting my nvidia overlay mode.
Thanks all the same
Reply to JTS
haha, yes, thats also something that will affect all your software programs, duh!!
cheers
Reply to superboss
There are 1261 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
