Archived from groups: alt.sys.pc-clone.dell (More info?)
System: Dell Inspiron 8500 with Windows XP Pro
I had to wipe my HD and reinstall the OS and all my software.
Before doing this, when I pressed the volume up/down button or the mute
button, a little horizontal red status bar would appear just above the
system tray.
No longer.
I'd like it back; I found it a very helpful visual representation of the
volume level, plus an easy way to tell if I had sound muted or not
without actually having to play audio file.
I'm guessing it's some Dell application I need to reinstall, or some
option I need to enable on some already-installed software, but what?
I've already tried checking Accessories -> Entertainment -> Volume
Control. If it's there, I can't find it.
