Tom's Hardware > Forum > Systems > Dell > XPS D300 Won't power on
Forum Systems : Dell - XPS D300 Won't power on
Archived from groups: alt.sys.pc-clone.dell (More info?)
My old XPS D300 won't turn on. Never had any problem, still original
everything except Win98. Does it sound like the power supply? When you
push the power button nothing happens. If it is the power supply do I have
to buy a Dell or is there another one? Thanks Jeff
Sponsored Links
Does that thing have a reset button on the back, near the power switch? If
you push the power button, assuming the unit is plugged into a working
receptacle, and nothing happens, you need a new power supply. But, to be
sure, test the one in the system with a circuit tester. You can order a
power supply from Dell or do some old-fashioned phone calling to confirm
that a unit other than a Dell power supply will work in your system.
"Jeff" <Jeff@nospam.com> wrote in message
news:_5rqe.13463$hg.1449@fe12.lga...
have
Reply to Anonymous
Doubtful that anything but a Dell-branded power supply would work. The XPS D300
is from the P2-P3 epoch when Dell made ATX-like systems. Motherboard and power
supply looked exactly like ATX, but the wiring from power supply to the
motherboard connector was/is different.
Also doubtful that Dell stocks power supplies for systems made in 1997 or 1998.
The OP is much more likely to find one at a local all-purpose computer store or
on eBay, for very short money either way... Ben Myers
>have
Reply to Anonymous
Thanks I will check around to see who stocks one. Jeff
<ben_myers_spam_me_not @ charter.net (Ben Myers)> wrote in message
news:42aabe90.2178240@nntp.charter.net...
> XPS D300
> power
> 1998.
> store or
>>If
>>have
Reply to jeff
Update Dell still does stock it. Jeff
news:dZzqe.72930$NZ1.51495@fe09.lga...
>> XPS D300
>> power
>> 1998.
>> store or
>>>If
>>>> you
>>>have
Reply to jeff
There are 789 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
