G
Guest
Guest
I have read the "GeForce 3 & WinXp problem" t hread and I was amazed to see (well, maby not), that the exacly same problem exists on my WinXp with my
GeForce2 GTS Pro (on a Giga-Byte 7DXR).....it seems that the WHQL driver - 21.83- makes more problems then the last one, example of this is that if I play Unreal (or doing everything else in that matter), from time to time it gets stuck, I checked in the Windows event viewer and it reported that a system
err has detected that was caused by an endless loop, it continued and reported that it was or the driver or the GeForce card that caused it, and since it all was fine with the older drivers I have to presume that its the driver fault.
The same thing happened to ppl I know...I tried to email Nvidia but no can do, I can only email Giga-Byte (I have a GF-2100 card) which dont have any clue about the problem, all I can do is to report the problem to Microsoft and wait..
Ron C.
Ron C.
