Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > audio device not detected
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
No sound is heared from speakers.OnBoard sound card was deactivated from
BIOS, and new Creative soundcard installed.
Creative Diagnostics performed a "PASS" for Hardware and a complete "FAIL"
for all software test results.When I click on creative volume control I
receive a message "The audio device supported by this application is not
detected".
I have no yellow question marks in the Device Manager of the "System" in the
Control Panel.
The DirectX Diagnotic program gives me "No sound card was found"
If I try clicking the Device Control icon in the control panel I get a
RUNDLL Error saying:AN EXCEPTION OCCURRED WHILE TRYING TO RUN
"C:\WINDOWS\system32\shell32.dll,Conrol_runDLL
"C:\WINDOWS\system32\USBAudio.cpl",Device Control
What should I do?
Sponsored Links
Did you uninstall the old drivers from your onboard sound? May have a
conflict with the new Sound Blaster Drivers. My other suggestion is to
uninstall the Creative drivers and reinstall updating the drivers from the
Creative Website. If all this fails try placing the sound card in a different
PCI slot and make sure you don't have to disable the onboard sound via jumper
on the motherboard.
> detected".
> Control Panel.
> What should I do?
Reply to Anonymous
Did you install the Creative drivers????
"RMA" <RMA@discussions.microsoft.com> wrote in message
news:A74E3587-C350-4D9E-9E25-04A678B762C8@microsoft.com...
> detected".
> the
> Control Panel.
> What should I do?
Reply to Anonymous
- 0 +
Yes I installed the Creative Drivers. Since I decided to buy the cReative
Sound Card because I thought that the onboard sound card was not working,
what are the system files that might not be detecting the card,maybe thay got
corrupted or have got missing. This all happened when I detected some bad
sectors on the hard disc and they were automatically fixed with a SCAN
Disc,who knows?
What I remember is that on the System Hardware Device Manager I used to have
an item in the sound section called "Microsoft Kernal System Audio Device"
which now has disappeared.
Any ideas?
> > detected".
> > the
> > Control Panel.
> > What should I do?
Reply to RMA
There are 519 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
