Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Programme access & defaults problem
Forum Windows XP : General Discussion Programme access & defaults problem
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Hi,
just installed XP on a new system I've built. Running fine, except a problem
message at startup -
"Either there is no default mail client, or the current mail client cannot
fulfill the messaging request. Please rub MS Outlook & set it as the default."
- except that Outlook Express is configured and working, along with IE
etc., all fine, appropriate programs selected in Internet options.
However, go to "Programme access & defaults", and "Microsoft Defaults" will
not stay selected, keeps reverting to "Custom / Other" mail & browser.
Hope someone can help (unable to use MS e-mail support as this is a
home-built "OEM" version. -
Martin
Reply to martin
"Martin" <Martin@discussions.microsoft.com> wrote in message
news:6EA1D9EB-046D-4F78-9EEF-EC747A8CA650@microsoft.com...
> Hi,
> problem
> default."
> will
> Martin
This may help you,
Send To Mail Recipient option does nothing
http://windowsxp.mvps.org/sendtomail.htm
Run the following two command in the Run dialog box
MSIMN.EXE /REG
and
regsvr32 "%ProgramFiles%\Outlook Express\msoe.dll"
[Courtesy of Ramesh Srinivasan, MVP]
William
Reply to Anonymous
- 0 +
Thanks, I'll try that.
Martin
> > Hi,
> > problem
> > default."
> > will
> > Martin
> This may help you,
> MSIMN.EXE /REG
> and
> William
Reply to martin
- 0 +
No Luck, unfortunately.
Martin
> > Hi,
> > problem
> > default."
> > will
> > Martin
> This may help you,
> MSIMN.EXE /REG
> and
> William
Reply to martin
Martin,
Try mailto:somename@som1111.com from Start, Run. Does Outlook Express open?
This is to test if the mailto: associations are fine.
Also, post the startup log here. Some startup application is probably
launching mailto: or initiating a MAPI call.
Type MSINFO32.EXE in Start, Run dialog
Click the (+) sign in Software Environment category
Select Startup Programs. System Information will now generate the list of
startup entries.
Once the right-pane is populated, click the File menu and choose Export
Type-in a file name (example: startuplog.txt) and choose a location to save
the file.
Close MSINFO32 utility.
Ramesh, Windows XP MVP
news:9EBC5ADF-6CFC-47B1-88AC-FCD2D3ED5C17@microsoft.com...
> Martin
Reply to Anonymous
There are 2336 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Windows Xp Blue Screen
By nhasian, 16 hours ago:
looks like the problem was caused by the nvidia display driver or the gpu itself. try...
Best offers
Top experts
