G
Guest
Guest
Hi all!
Just put together my new system:
amd athlon xp1800
512mb crucial ram
epox 8kha+
gainward geforce3 ti-200
windows xp pro
soundblaster Live! card
The installation went fine and windows is running very smooth but I can't run any games nor the WinDVD software that came with the card.
Everytime I try to start up a game it either freezes, screen goes totally bonkers or I'm in the game but I only hear sound.
The end result is that I always have to reboot.
As far as drivers, I've tried these detonator drivers so far:
21.83(WHQL)
21.81(WHQL)
plus a lot of earlier ones. Always the same result.
Something that I think might pertain to the problem is that when I run dxdiag all the test options under the tab where you test the different aspects of directX are greyed out exept one(directDraw I think) so it's like the card is not behaving properly.
Does anyone have any suggestion as to what I can do in order to fix this?
Any help is deeply appreciated:
Viktor A Lundberg
amd athlon xp1800
512mb crucial ram
epox 8kha+
windows xp pro
21.83(WHQL)
21.81(WHQL)
Viktor A Lundberg
