Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > help, my cd-rw drive door is stuck...
Forum Windows XP : Windows XP General Discussion - help, my cd-rw drive door is stuck...
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
And I probably made the problem 100 times worse. I went into the device
manager, selected find hardware changes or something like that, and the next
thing I know, its missing/deleted from the system. How do I get it back on
the system and figure out why the door won't open so I can burn a cd? Thanks.
Sponsored Links
In news:2B6E0E13-2E1A-4D3C-8C91-66A9EB69596A@microsoft.com,
harleyroan22 <harleyroan22@discussions.microsoft.com> had this to say:
My reply is at the bottom of your sent message:
> device manager, selected find hardware changes or something like
> that, and the next thing I know, its missing/deleted from the system.
> How do I get it back on the system and figure out why the door won't
Rebooting should re-install the drivers. The again maybe it's died? It could
be the drive is actually dead, not getting power, or that the cable is
broken. Take a bent paperclip and push it in the hole on the front of the
drive, that will undo the catch, if there's power to it you should then be
able to open it with the button (keep pressing in while doing so) or
manually with long fingernails and a lot of swearing.
Galen
"Chance has put in our way a most singular and whimsical problem, and
its solution is its own reward."
Sherlock Holmes
Reply to galen
there is no small hole on the front of the door at all. and I already
restarted the computer and this stupid computer still doesnt recognize that
there is an F drive.
> Galen
> Sherlock Holmes
Reply to Anonymous
- 0 +
In news:A7E42FB2-9678-4DE0-BD3A-3C5C98369460@microsoft.com,
> recognize that there is an F drive.
>> say:
>>> system. How do I get it back on the system and figure out why the
>> It could be the drive is actually dead, not getting power, or that
>> the cable is broken. Take a bent paperclip and push it in the hole
>> on the front of the drive, that will undo the catch, if there's
>> power to it you should then be able to open it with the button (keep
>> pressing in while doing so) or manually with long fingernails and a
>> lot of swearing.
>> Galen
>> Sherlock Holmes
There's no hole under the tray??? How dreadfully odd... You should check the
cables next and/or try this handy dandy script from Doug Knox MVP...
Restore CD/DVD Drives to Explorer:
http://www.dougknox.com/xp/scripts [...] vd_fix.htm
Galen
Sherlock Holmes
Reply to galen
There are 523 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
