Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
I turned off system restore to eliminate the current restore points. Now I
can't start system restore because there is no longer a System Restore tab.
I get the following errors in the System event log:
Event Type: Error
Event Source: SRService
Event Category: None
Event ID: 104
Date: 8/21/2005
Time: 20:45:23
User: N/A
Computer: D875PBZ
Description:
The System Restore initialization process failed.
Data:
0000: 05 00 00 00 ....
Event Type: Error
Event Source: Service Control Manager
Event ID: 7023
Date: 8/21/2005
Time: 20:45:13
User: N/A
Computer: D875PBZ
Description:
The System Restore Service service terminated with the following error:
Access is denied.
I reinstalled sr.inf but that hasn't helped.
Help!
TIA
Regards,
Sam Holbrook
Try this, go to the start button, run, type in gpedit.msc, click
administrative templates, system, system restore and see - turn off system
restore/config, click properties and mark not configured..
j;-)
> Event Type: Error
> Event ID: 104
> Date: 8/21/2005
> Time: 20:45:23
> User: N/A
> Computer: D875PBZ
> Description:
> Data:
> Event Type: Error
> Event ID: 7023
> Date: 8/21/2005
> Time: 20:45:13
> User: N/A
> Computer: D875PBZ
> Description:
> Access is denied.
> Help!
> TIA
> Regards,
> Sam Holbrook
For future reference the Disk Cleanup utility (in Accessories - System
Tools) has an advanced option that will remove all but the most recent
System Restore point.
Also see MVP Bert Kinney's System Restore pages:
http://bertk.mvps.org/index.html for addtional information and advice
regarding System Restore.
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Hi Sam,
Here are the instruction on regaining the System Restore Tab.
http://bertk.mvps.org/html/tips.html#DisabledByPolicy
Regards,
Bert Kinney MS-MVP Shell/User
> restore points. Now I can't start system restore because
> there is no longer a System Restore tab. I get the
> Event Type: Error
> Event ID: 104
> Date: 8/21/2005
> Time: 20:45:23
> User: N/A
> Computer: D875PBZ
> Description:
> Data:
> Event Type: Error
> Event ID: 7023
> Date: 8/21/2005
> Time: 20:45:13
> User: N/A
> Computer: D875PBZ
> Description:
> following error: Access is denied.
> Help!
> TIA
> Regards,
> Sam Holbrook
Bert,
How do I find out what it is that 'access is denied' to?
TIA
Regards,
Sam Holbrook
"Bert Kinney" <bert@NSmvps.org> wrote in message
news:%23GTcoxKqFHA.2592@TK2MSFTNGP12.phx.gbl...
> Hi Sam,
> Regards,
>> Event Type: Error
>> Event ID: 104
>> Date: 8/21/2005
>> Time: 20:45:23
>> User: N/A
>> Computer: D875PBZ
>> Description:
>> Data:
>> Event Type: Error
>> Event ID: 7023
>> Date: 8/21/2005
>> Time: 20:45:13
>> User: N/A
>> Computer: D875PBZ
>> Description:
>> Help!
>> TIA
>> Regards,
>> Sam Holbrook
Hi Sam,
The fact that the System Restore tab is missing indicates a policy was set to deny access
to SR.
This can be set via Security Setting, a registry edit, or as I suspect, by virus/malware
infection.
Follow these instruction on regain the System Restore Tab in System Properties.
Regards,
Sam Holbrook wrote:
> Bert,
> TIA
> Regards,
> Sam Holbrook
> "Bert Kinney" wrote
>> Hi Sam,
>> Tab.
>> http://bertk.mvps.org/html/tips.html#DisabledByPolicy --
>> Regards,
>>> because there is no longer a System Restore tab. I get
>>> Event Type: Error
>>> Event ID: 104
>>> Date: 8/21/2005
>>> Time: 20:45:23
>>> User: N/A
>>> Computer: D875PBZ
>>> Description:
>>> Data:
>>> Event Type: Error
>>> Event ID: 7023
>>> Date: 8/21/2005
>>> Time: 20:45:13
>>> User: N/A
>>> Computer: D875PBZ
>>> Description:
>>> Help!
>>> TIA
>>> Regards,
>>> Sam Holbrook
Bert,
Still no Tab.
Using secpol.msc what security policy do I need to activate with fail to
create a log in security folder the item that 'access is denied' refers to?
Regards,
Sam Holbrook
news
pLk8qlqFHA.3544@TK2MSFTNGP15.phx.gbl...
> Hi Sam,
> to deny access to SR.
> virus/malware infection.
> Properties.
> Regards,
> Sam Holbrook wrote:
>> Bert,
>> TIA
>> Regards,
>> Sam Holbrook
>> "Bert Kinney" wrote
>>> Hi Sam,
>>> Tab.
>>> Regards,
>>>> Event Type: Error
>>>> Event ID: 104
>>>> Date: 8/21/2005
>>>> Time: 20:45:23
>>>> User: N/A
>>>> Computer: D875PBZ
>>>> Description:
>>>> Data:
>>>> Event Type: Error
>>>> Event ID: 7023
>>>> Date: 8/21/2005
>>>> Time: 20:45:13
>>>> User: N/A
>>>> Computer: D875PBZ
>>>> Description:
>>>> Help!
>>>> TIA
>>>> Regards,
>>>> Sam Holbrook
Following the instructions provided, is the System Restore visible?
I am not familiar with the policy question you are referring to.
Regards,
Sam Holbrook wrote:
> Bert,
> Still no Tab.
> activate with fail to create a log in security folder the
> Regards,
> Sam Holbrook
> news
>> Hi Sam,
>> indicates a policy was set to deny access to SR.
>> or as I suspect, by virus/malware infection.
>> Regards,
>> Sam Holbrook wrote:
>>> Bert,
>>> TIA
>>> Regards,
>>> Sam Holbrook
>>> "Bert Kinney" wrote
>>>> Hi Sam,
>>>> Restore Tab.
>>>> -- Regards,
>>>>> Event Type: Error
>>>>> Event ID: 104
>>>>> Date: 8/21/2005
>>>>> Time: 20:45:23
>>>>> User: N/A
>>>>> Computer: D875PBZ
>>>>> Description:
>>>>> Data:
>>>>> Event Type: Error
>>>>> Event ID: 7023
>>>>> Date: 8/21/2005
>>>>> Time: 20:45:13
>>>>> User: N/A
>>>>> Computer: D875PBZ
>>>>> Description:
>>>>> Help!
>>>>> TIA
>>>>> Regards,
>>>>> Sam Holbrook
Bert,
No. Control Panel, Performance and Maintenance, System no longer has a
System Restore tab. However, on the Performance and Maintenance panel under
'See Also' there is an icon System Restore. When I double click, I get
"System Restore is not able to protect your computer. Please restart your
computer, and then run System Restore again.".
After restart and after cold boot same icon same no tab same message. I use
NAV and NPF faithfully, do weekly system scans with NAV, spybot and adaware.
The event log for security does't log anything by default. You have set,
for example, protected system file accesses to successful and/or failure
from default none to get security event logging.
Regards,
Sam Holbrook
>news:%23$iZ%23r9qFHA.1788@tk2msftngp13.phx.gbl...
> Regards,
> Sam Holbrook wrote:
>> Bert,
>> Still no Tab.
>> Regards,
>> Sam Holbrook
>> news
>>> Hi Sam,
>>> Regards,
>>> Sam Holbrook wrote:
>>>> Bert,
>>>> TIA
>>>> Regards,
>>>> Sam Holbrook
>>>> "Bert Kinney" wrote
>>>>> Hi Sam,
>>>>> Restore Tab.
>>>>> -- Regards,
>>>>>> Event Type: Error
>>>>>> Event ID: 104
>>>>>> Date: 8/21/2005
>>>>>> Time: 20:45:23
>>>>>> User: N/A
>>>>>> Computer: D875PBZ
>>>>>> Description:
>>>>>> Data:
>>>>>> Event Type: Error
>>>>>> Event ID: 7023
>>>>>> Date: 8/21/2005
>>>>>> Time: 20:45:13
>>>>>> User: N/A
>>>>>> Computer: D875PBZ
>>>>>> Description:
>>>>>> Help!
>>>>>> TIA
>>>>>> Regards,
>>>>>> Sam Holbrook
At this point I would suggest reinstalling System Restore.
http://bertk.mvps.org/html/tips.html#ReinstallSR
Regards,
Sam Holbrook wrote:
> Bert,
> no longer has a System Restore tab. However, on the
> Performance and Maintenance panel under 'See Also' there
> "System Restore is not able to protect your computer. Please restart your computer, and
> then run System Restore again.". After restart and after cold boot same icon same no
> tab
> same message. I use NAV and NPF faithfully, do weekly
> default. You have set, for example, protected system
> file accesses to successful and/or failure from default
> Regards,
> Sam Holbrook
>> Restore visible? I am not familiar with the policy question you are
>> referring to. --
>> Regards,
>> Sam Holbrook wrote:
>>> Bert,
>>> Still no Tab.
>>> Regards,
>>> Sam Holbrook
>>> news
>>>> Hi Sam,
>>>> Regards,
>>>> Sam Holbrook wrote:
>>>>> Bert,
>>>>> to? TIA
>>>>> Regards,
>>>>> Sam Holbrook
>>>>> "Bert Kinney" wrote
>>>>>> Hi Sam,
>>>>>> Restore Tab.
>>>>>> -- Regards,
>>>>>>> Event Type: Error
>>>>>>> Event ID: 104
>>>>>>> Date: 8/21/2005
>>>>>>> Time: 20:45:23
>>>>>>> User: N/A
>>>>>>> Computer: D875PBZ
>>>>>>> Description:
>>>>>>> Data:
>>>>>>> Event Type: Error
>>>>>>> Event ID: 7023
>>>>>>> Date: 8/21/2005
>>>>>>> Time: 20:45:13
>>>>>>> User: N/A
>>>>>>> Computer: D875PBZ
>>>>>>> Description:
>>>>>>> the following error: Access is denied.
>>>>>>> Help!
>>>>>>> TIA
>>>>>>> Regards,
>>>>>>> Sam Holbrook
Bert,
Already done. See original post. Last sentence.
Regards,
Sam Holbrook
news:u00bVs%23qFHA.3216@TK2MSFTNGP12.phx.gbl...
> Regards,
> Sam Holbrook wrote:
>> Bert,
>> computer, and then run System Restore again.". After restart and after
>> Regards,
>> Sam Holbrook
>>> referring to. --
>>> Regards,
>>> Sam Holbrook wrote:
>>>> Bert,
>>>> Still no Tab.
>>>> Regards,
>>>> Sam Holbrook
>>>> news
>>>>> Hi Sam,
>>>>> Regards,
>>>>> Sam Holbrook wrote:
>>>>>> Bert,
>>>>>> to? TIA
>>>>>> Regards,
>>>>>> Sam Holbrook
>>>>>> "Bert Kinney" wrote
>>>>>>> Hi Sam,
>>>>>>> Restore Tab.
>>>>>>> -- Regards,
>>>>>>>> Event Type: Error
>>>>>>>> Event ID: 104
>>>>>>>> Date: 8/21/2005
>>>>>>>> Time: 20:45:23
>>>>>>>> User: N/A
>>>>>>>> Computer: D875PBZ
>>>>>>>> Description:
>>>>>>>> Data:
>>>>>>>> Event Type: Error
>>>>>>>> Event ID: 7023
>>>>>>>> Date: 8/21/2005
>>>>>>>> Time: 20:45:13
>>>>>>>> User: N/A
>>>>>>>> Computer: D875PBZ
>>>>>>>> Description:
>>>>>>>> Help!
>>>>>>>> TIA
>>>>>>>> Regards,
>>>>>>>> Sam Holbrook
OK.
I have not seen the registry edit to restore the SR tab not work when logged on as
Administrator.
I would then suspect there's a application/virus interfering with SR and suggest
uninstalling NAV and any other Norton products. Then retry the registry edit to restore
the tab.
Here's some more information on the issue.
System Restore Group Policy restrictions
http://windowsxp.mvps.org/srpolicy.htm
Regards,
Sam Holbrook wrote:
> Bert,
> Regards,
> Sam Holbrook
>> Restore. http://bertk.mvps.org/html/tips.html#ReinstallSR
>> Regards,
>> Sam Holbrook wrote:
>>> Bert,
>>> Please restart your computer, and then run System
>>> same icon same no tab same message. I use NAV and NPF faithfully, do weekly
>>> Regards,
>>> Sam Holbrook
>>>> question you are referring to. --
>>>> Regards,
>>>> Sam Holbrook wrote:
>>>>> Bert,
>>>>> Still no Tab.
>>>>> Regards,
>>>>> Sam Holbrook
>>>>> news
>>>>>> Hi Sam,
>>>>>> edit, or as I suspect, by virus/malware infection.
>>>>>> Regards,
>>>>>> Sam Holbrook wrote:
>>>>>>> Bert,
>>>>>>> to? TIA
>>>>>>> Regards,
>>>>>>> Sam Holbrook
>>>>>>> "Bert Kinney" wrote
>>>>>>>> Hi Sam,
>>>>>>>> Restore Tab.
>>>>>>>> -- Regards,
>>>>>>>>> current restore points. Now I can't start system
>>>>>>>>> Restore tab. I get the following errors in the
>>>>>>>>> System event log: Event Type: Error
>>>>>>>>> Event ID: 104
>>>>>>>>> Date: 8/21/2005
>>>>>>>>> Time: 20:45:23
>>>>>>>>> User: N/A
>>>>>>>>> Computer: D875PBZ
>>>>>>>>> Description:
>>>>>>>>> Data:
>>>>>>>>> Event Type: Error
>>>>>>>>> Event ID: 7023
>>>>>>>>> Date: 8/21/2005
>>>>>>>>> Time: 20:45:13
>>>>>>>>> User: N/A
>>>>>>>>> Computer: D875PBZ
>>>>>>>>> Description:
>>>>>>>>> Help!
>>>>>>>>> TIA
>>>>>>>>> Regards,
>>>>>>>>> Sam Holbrook
Is the system restore service disabled in services.msc? If so, set to
automatic in it's properties.. Sart, run, type "services.msc" scroll to
system restore and double click..
j;-)
> Bert,
> Regards,
> Sam Holbrook
> > Regards,
> > Sam Holbrook wrote:
> >> Bert,
> >> Regards,
> >> Sam Holbrook
> >>> referring to. --
> >>> Regards,
> >>> Sam Holbrook wrote:
> >>>> Bert,
> >>>> Still no Tab.
> >>>> Regards,
> >>>> Sam Holbrook
> >>>> news
> >>>>> Hi Sam,
> >>>>> Regards,
> >>>>> Sam Holbrook wrote:
> >>>>>> Bert,
> >>>>>> to? TIA
> >>>>>> Regards,
> >>>>>> Sam Holbrook
> >>>>>> "Bert Kinney" wrote
> >>>>>>> Hi Sam,
> >>>>>>> Restore Tab.
> >>>>>>> -- Regards,
> >>>>>>>> Event Type: Error
> >>>>>>>> Event ID: 104
> >>>>>>>> Date: 8/21/2005
> >>>>>>>> Time: 20:45:23
> >>>>>>>> User: N/A
> >>>>>>>> Computer: D875PBZ
> >>>>>>>> Description:
> >>>>>>>> Data:
> >>>>>>>> Event Type: Error
> >>>>>>>> Event ID: 7023
> >>>>>>>> Date: 8/21/2005
> >>>>>>>> Time: 20:45:13
> >>>>>>>> User: N/A
> >>>>>>>> Computer: D875PBZ
> >>>>>>>> Description:
> >>>>>>>> Help!
> >>>>>>>> TIA
> >>>>>>>> Regards,
> >>>>>>>> Sam Holbrook
Jaymon,
The System Restore Service is okay.
Thanks for the suggestion.
Regards,
Sam Holbrook
"Jaymon" <Jaymon@discussions.microsoft.com> wrote in message
news:9C0C0832-38E6-4996-B51F-CC23D73E1D4F@microsoft.com...
> j;-)
>> Bert,
>> Regards,
>> Sam Holbrook
>> > Regards,
>> > Sam Holbrook wrote:
>> >> Bert,
>> >> your
>> >> after
>> >> Regards,
>> >> Sam Holbrook
>> >>> referring to. --
>> >>> Regards,
>> >>> Sam Holbrook wrote:
>> >>>> Bert,
>> >>>> Still no Tab.
>> >>>> Regards,
>> >>>> Sam Holbrook
>> >>>> news
>> >>>>> Hi Sam,
>> >>>>> Regards,
>> >>>>> Sam Holbrook wrote:
>> >>>>>> Bert,
>> >>>>>> to? TIA
>> >>>>>> Regards,
>> >>>>>> Sam Holbrook
>> >>>>>> "Bert Kinney" wrote
>> >>>>>>> Hi Sam,
>> >>>>>>> Restore Tab.
>> >>>>>>> -- Regards,
>> >>>>>>>> Event Type: Error
>> >>>>>>>> Event ID: 104
>> >>>>>>>> Date: 8/21/2005
>> >>>>>>>> Time: 20:45:23
>> >>>>>>>> User: N/A
>> >>>>>>>> Computer: D875PBZ
>> >>>>>>>> Description:
>> >>>>>>>> Data:
>> >>>>>>>> Event Type: Error
>> >>>>>>>> Event ID: 7023
>> >>>>>>>> Date: 8/21/2005
>> >>>>>>>> Time: 20:45:13
>> >>>>>>>> User: N/A
>> >>>>>>>> Computer: D875PBZ
>> >>>>>>>> Description:
>> >>>>>>>> Help!
>> >>>>>>>> TIA
>> >>>>>>>> Regards,
>> >>>>>>>> Sam Holbrook
Bert,
My gut feeling is that srservice is not able to access my C: or F: SVI
folder to write the drivetable.txt file or the restore files themselves.
Do you know a security policy guru that can help set policies to log events
to the Security event log for the system event ID 104 error type 5: access
is denied
or should I post a new question to windowsxp.security_admin?
Regards,
Sam Holbrook
news:%23jrXIj$qFHA.2540@TK2MSFTNGP09.phx.gbl...
> OK.
> logged on as Administrator.
> suggest uninstalling NAV and any other Norton products. Then retry the
> registry edit to restore the tab.
> Regards,
> Sam Holbrook wrote:
>> Bert,
>> Regards,
>> Sam Holbrook
>>> Regards,
>>> Sam Holbrook wrote:
>>>> Bert,
>>>> weekly
>>>> Regards,
>>>> Sam Holbrook
>>>>> Regards,
>>>>> Sam Holbrook wrote:
>>>>>> Bert,
>>>>>> Still no Tab.
>>>>>> Regards,
>>>>>> Sam Holbrook
>>>>>> news
>>>>>>> Hi Sam,
>>>>>>> Regards,
>>>>>>> Sam Holbrook wrote:
>>>>>>>> Bert,
>>>>>>>> to? TIA
>>>>>>>> Regards,
>>>>>>>> Sam Holbrook
>>>>>>>> "Bert Kinney" wrote
>>>>>>>>> Hi Sam,
>>>>>>>>> Restore Tab.
>>>>>>>>> -- Regards,
>>>>>>>>>> Event ID: 104
>>>>>>>>>> Date: 8/21/2005
>>>>>>>>>> Time: 20:45:23
>>>>>>>>>> User: N/A
>>>>>>>>>> Computer: D875PBZ
>>>>>>>>>> Description:
>>>>>>>>>> Data:
>>>>>>>>>> Event Type: Error
>>>>>>>>>> Event ID: 7023
>>>>>>>>>> Date: 8/21/2005
>>>>>>>>>> Time: 20:45:13
>>>>>>>>>> User: N/A
>>>>>>>>>> Computer: D875PBZ
>>>>>>>>>> Description:
>>>>>>>>>> Help!
>>>>>>>>>> TIA
>>>>>>>>>> Regards,
>>>>>>>>>> Sam Holbrook
There are 1131 identified and unidentified users. To see the list of identified users, Click here.
