Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > ATI Radeon 8500 Problems, Please help
Forum Graphic & Displays : Graphics Cards - ATI Radeon 8500 Problems, Please help
I bought an ati radeon 8500 about a week ago and i can't get everything working. I am running an athlon 1.2Ghz on an iwill mobo with the Ali Magic 1 chipset. has anyone heard about compatability issues with this mobo, or chipset?
text is garbled and messiah, max payne, and aquanox all cause problems.
Sponsored Links
did you do a clean install with ati cd i have a radeon and they recomend no drivers preinstalled just install card then reboot place in cd and follow dir but if not
go here and you get ati's support
<A HREF="http://support.ati.com/?parent=0&folder=66&doc=51" target="_new">http://support.ati.com/?parent=0&folder=66&doc=51</A>
Reply to ycs46241
Your best bet is to go to <A HREF="http://rage3d.com" target="_new">http://rage3d.com</A>. A very friendly community that will be able to help you out :smile: .
Reply to noko
Did you install the updated drivers? The supplied drivers have a flaw that prevents them from working on many AMD systems, the new driver (available on ATI's website) fixes that and many other issues.
What's the frequency, Kenneth?
Reply to Crashman
Yeah i tryed the new drivers and i have tryed winxp, 98 SE, and ME, all with every combination of drivers possible, i also tryed installing a new agp driver for my motherboard and that also did not solve the problem. Thanks for the help though
Reply to Anonymous
There are 528 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
