G
Guest
Guest
Hello,
I have a real problem. My girlfriend surprised me with an early Christmas present…and brand new shiny 3D Prophet 3 Ti 500!!! -YAY! Now…as grateful as I am, I do have some problems with it:
I was originally running Win2kpro, I uninstalled my previous card drivers (for a GF2GTS Pro 64mb), took out the old card, put in the new one, booted into Windows and chose “Standard VGA”, used NV Cleaner (which subsequently did not remove anything), then installed the new drivers for my new card. I go to run 3dmark 2k1…. runs the first test fine…then locks. I re-boot, try again…locks during the first two seconds of the first test this time. I thought that maybe I would do well to go ahead and uninstall 3dmark and re-install it as I have changed cards and maybe experiencing some residual weirdness. After I re-install 3dmark…same problem!! I try running 3dmark 2k…same result. I tried Quake 3 to see if this was a universal problem, or just something wonkey with 3dmark, runs like a jem…not quite as fast as I expected (78fps at 1280x1024 HQ settings)…but I am experiencing other random weirdness thus far, so I write it off.
At this point I said to myself, “ok Jack, you’ve gone almost a whole year without a fresh O/S, let’s go ahead and re-install Windows.” I chose to use Win98SE this time, as I remembered that I got better performance with that O/S on one of my friends PC’s with my exact same specs (I use Win2kpro for the stability). I do a complete format and install Win98SE, guess what…. exact same problem. For shizits and giggles, I install Max Payne to determine if it’s a D3D only problem…. plays friggin great for a few minutes…then locks up and dumps me to the desktop. Quake 3…flawless…sorry, I did this all this morning before I came into work and did not bench Q3 under Win98SE.
I ran dxdiag and got through the entire set of tests fine. I checked that my AGP aperture was set to 64mb, and everything else is the same as when I had my GF2pro in. What the hell is going on!!! Could I truly have a defective card, gosh that would suck!
Please HELP
-Jack
P3800e
256mb PC133
Maxtor 20GB 7200Rpm
Biostar MV6CG
OLD-GF2GTSPRO64mb NEW-3dProphet 3 Ti 500
Driver usage-21.81 21.83 (newest on Nvidia site)
Please HELP
-Jack
P3800e
256mb PC133
Maxtor 20GB 7200Rpm
Biostar MV6CG
