Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > No sound on webcam - setting issue?
Forum Windows XP : Windows XP General Discussion - No sound on webcam - setting issue?
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
Can anyone help me here? We bought a Digital Product PC Camera with
microphone, and installed as directed with the CD driver provided. However,
the camera doesn't seem to be picking up sound. Thing is, I've tried
another separate microphone, with zero results, suggesting that there is a
'setting' issue on the PC.
? I am correct to plug into the pink socket labelled with a microphone, I
presume?
Is there any obvious setting that might be preventing the microphones from
recording onto video snippets? I have tried the sound record program, and
just get a 'flat-line' on the display.
Any advice is hugely appreciated.
Chris
Sponsored Links
There's a bunch of places to check. First, double click on the little sound
icon in the system tray in the lower right corner of your screen. Check the
microphone settings - if they're not available check the Advanced setting in
the menu options. Then, check in Control Panel under Sound and Multimedia
Devices, for utilities related to your sound card, and for the program that
was installed by the PC Camera software. Then, check in your start menu for
options for all 3 of these.
> presume?
> Chris
Reply to Anonymous
There are 1257 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
