running dual monitors with the Geforce3
  • Graphics Cards
  • Dual Monitors
  • DVI
  • VGA
  • Graphics
December 9, 2001 4:59:09 PM
Can you run a dual monitor setup with the GeForce3 using the DVI connector and getting a VGA adapter? Just wanted to know if that will work.
More about : running dual monitors geforce3
December 9, 2001 11:37:57 PM
I've never heard of GeForce3 having dual output. Nor do they have a pci version as of yet, as far as I know. Even if they do, you can't do opengl across both. Something like the GeForce2 MX dual, ATI Radeon 8500, or ATI Radeon 7500, you can.
December 10, 2001 12:49:44 AM
if I got a GeForce 3 now, and later when I wanted to set up dual monitors could I just get a decent PCI card and hook the second monitor up to that? even if it is an older card.
December 10, 2001 6:14:22 AM
i believe you can, but make sure to set your agp slot to your first viewable device, otherwise your games will be played on your pci card
December 10, 2001 2:02:53 PM
cool, thanks
December 11, 2001 7:13:27 AM
I have done it before. Works great But I dont use the dual monitors much.
December 11, 2001 12:23:16 PM
You can get a GeForce3 now and add a PCI card to have dual monitor set up. My computer have GeForce on my AGP slot and ATI All in wonder 128 pro in my PCI slot. The computer works great.
December 11, 2001 12:24:53 PM
You can switch the primary monitor in Windows 2000(not sure about win 98). It does not even require a reboot.
December 11, 2001 12:50:35 PM
I've had a few problems using dual nVidia cards to do dual monitor setups. The problem arrises from two cards using one driver with two different settings (ala nVidia unified driver). Use the GF3 with a non-nvidia card and you shouldn't have trouble.
